scottp628
- Pacific North West
looking for a manufacturer for a new fused distribution panel, single or three phase if one is still being made, Edison or plug style, not a circuit breaker panel for a small factory/research lab.
I see no practical reason for this request.
However, you might look at Cooper/Bussmann. They make a fusible lighting panel.
An owner or designer does not need to have a "practical reason" for his or her requirements.I see no practical reason for this request.
And then the EC can sell them a new systemSays who! It will be the Ec they go to when they are dissatisfied with what they have.
Fresh Market grocery stores use fusible panels in some of their stores, 20 amp branch circuits, it's been a while since I've seen one, but it kinda looks like a regular breaker, but has a switch that has a fuseholder built in. I can't remember if it was Square D, or some off brand, but it would work well in your situation. Uses high AIC cartridge type fuses. 277/480 volt service.
As the arc-fault protection issue came to the forefront of concern it has been argued that fuses are superior to circuit breakers in that aspect. The question of course is then: is it safer to reset a breaker or replace a fuse.
When it comes to fuses being replaced by non electricians the breaker is probably the better choice. Otherwise if the fuse will fit in the fuseholder and it has a bigger number on it than the one that it replaced, then that is the best choice (to the person changing it).
Luckily most faults, especially those on branch circuits, are L-G arcing rather than L-L bolted.... breakers are only rated/tested to interrupt a full rated SC only once, ....
breakers are only rated/tested to interrupt a full rated SC only once, so if you reclose it on a fault it is more likely to present a hazard than a fuse.
Are manufacturers of breakers not supplying the maintenance schedules for the breakers to follow? or Are the breakers not maintained properly by field people?
Yea the fist time they have a brown out or power failure and stuff blows fuses on start up he'll be singing the blues.
Does this company have a full time service tech.
Incredibly, some places in my country would specify that main disconnects use fuses and not circuit breakers
