KD4UPL
- Swoope, VA
I install a lot of solar and battery back-up systems. A common situation for me is running a 240v submersible well pump motor from a 120v inverter. I use a 3kVA transformer to step up the voltage. Most well pumps I encounter draw 7 to 10 amps at 240v. I typically use a 30 amp SP breaker and 10-2 romex to feed the trans. primary. I then connect 10-2 romex from the secondary to the pump wires going to the well.
My question is how do I handle the grounding on the secondary side. There is no neutral wire on the secondary. I think I need to connect one of the secondary wires to the equipment grounding conductor. Does it matter which wire? Do I also connect this to the equipment grounding conductor in the romex feeding the primary side of the transformer?
I know this is really basic but I can't get my head around connecting a "hot" wire to a ground wire. It seems like it will be a direct short.
Thanks for any help you can give.
