 - Lockport, IL
 - Semi-Retired Electrical Engineer
We are upgrading an existing (very old) facility to add a smoke control system.  Building codes require the fan to have a backup power source.  The existing backup source is a battery system with an inverter that supplies 120 volt, single phase power.  The mechanical engineer wants to use a VFD to drive the smoke control fan, because that simplifies the process of balancing pressures and air flow rates.  But I can?t give a VFD a backup source from a 120 volt single phase supply.  The fan will be between 5 and 10 HP.  I can only think of two possible solutions.
			- Run the single phase power through an electronics gizmo that puts out three phase power.
 - Use a single phase motor, and make the ME do more work maintaining flow balances.
