hurk27
 - Portage, Indiana NEC: 2008
I hope this link works, it is a local NEC addendum for a jurisdiction that I compete for work in that requires marking of each feeder conductor, and the required color of the markings. They basically made a set of tables for 215.8 (which doesn't exist, yet).
OK, I checked the link in preveiw mde, it does work but starts you at the beginning of the code amendments. The NEC amendments are about halfway down the page.
http://library4.municode.com:80/def...fe12faeb57d60b7758132f0e565a4e&infobase=10323
Now what happens if all the supply houses in your area run out of a color or two on wires smaller then a #8, this was the reason they reversed this requirement a few years ago because it allows more flexibility in what colors you might have to use, you might not have all the colors available, and in this day and age of supply houses stocking bare minimum's its even harder to find what you need.
