- Chapel Hill, NC
- Retired Electrical Contractor
Nope that 24kw is a single phase. If you heat your water with electric and take showers just as long as before you will save on electric. You are not heating your water all day long.Technical Specifications3 x 40Aimensions: 17? x 16? x 3?Weight: 23 lbs.kW / Elements: 24 kW / 3 elementsMax. Amps: 100 A @ 240 VCustomer Double-PoleCircuit Breaker / FusedDisconnect Required:1 x 110A or2 x 60A or
Yeah I see in the picture but the model says 24Kw has the model # then 3 -I assumed that meant 3 phase 3 phase
