Ok here is a question I've got? Your boss tells you to install something a certain way which you know to be a violation of the codebook be it five 90s in a run between pull points or whatever. You inform boss of potential violation and are told to do it anyways its either A not getting inspected or B the inspector won't see it cause he can't get up the ladder to look. What would you do? Knowingly violate the code so that you can work or put your foot down and worry about the lay offs? Would the installing knowledgeable electrician be in jeopardy of losing their license for an illegal install if forbid something happens and someone got hurt or worse killed due to the negligent install.
Which leads me to another gripe I have like should inspectors have to be physically fit in order to renew their licences to inspect?
What do you think?
What do you think?
