T
T.M.Haja Sahib
Guest
Why should it be left to chance?Can we not safeguard ourselves against this risk?That's bad luck to be touching the pole during the five cycles of fault.
Do you think the video is inaccurate?I want your own interpretation in brief my dear friend for Mikeholt may not be available for further discussion.
By covering the planet in a sheet of copper to eliminate any possibility of electrical shock? :slaphead:Why should it be left to chance?Can we not safeguard ourselves against this risk?
90.1(A) Practical Safeguarding. The purpose of this Code is the practical safeguarding of persons and property from hazards arising from the use of electricity.
You asked why equipotential bonding around the pool is necessary, and the answer is explained in detail in the first couple minutes; to reduce the effect of NEV.
Perhaps it would be good for you to review this:
What exactly are you trying to achieve here?
You made a general comment in post no.71
The most dangerous aspect to a residence losing the grounded conductor is that electronic devices will smoke & the house can burn to the ground as 240 volts divides unevenly across the 120 volt loads that are now in series with each other across a 240 volt source.
Which I still stand by.
According to the source you referenced the system voltage is 22K ot 80K & only 8 amps of current back through the earth. I do not consider that a low impedance termination.
That only 8 amps of current back through the earth does not mean that touch voltage would be lower because of the system high voltage.The article under 'safety' describes how to achieve low impedance earth connection so that the SWER can operate safely.
That is just a possibility.Has that happened anywhere in U.S? Please give the statistics.
