- NE Nebraska
- EC
I mentioned in the OP free cooling systems were installed in telephone exchanges.
I already suggested it is an idea of brainstorming.
Do you believe electrical aspects of the problem are already thoroughly discussed or not?
I know you said where they were installed. You wanted to know why you have unexpected readings as compared to a previous period. The only way you will get an accurate comparison is if all conditions are the same during both periods. When I asked what exactly was measured that is what I meant. Were you comparing the energy used by cooling equipment only, cooling equipment and free cooling , the entire facility? If the entire facility, are you certain loads other than cooling were the same? Then comes the temperature and other conditions that may effect how much cooling is needed. If conditions I just mentioned were not the same for both periods being compared you can not determine changes of efficiency as you are not comparing the same conditions.
Most of this discussion (other than your questioning of the accuracy of the meter) is about energy concepts, and not necessarily electrical energy. Just general heating and cooling type concepts.
