Don't have to be invited and I, for one, appreciate your input.Sticking my nose in where I was not invited ... Semantics ... no LINEAR relationship, but yes, a direct versus an inverse relationship. AFAIK, with an operating motor at a constant voltage, there is no case where an increase in current does not reflect an increase in torque load.
dkarst is right.
Move out of the normal operating range and you get current and torque going in opposite directions.
See for example post #177.
Above about 94% speed, current and torque do go in the same direction and, in the normal region of operation, which is 99% of sync speed upwards, the current is approximately proportional to torque which accords with your experience.
Below that 94% speed, the current goes up but the torque reduces. The inverse relationship.
