Perfectly clear
Perfectly clear
This is what you get for reading the instructions:
1.
DETECTORS SHOULD BE PLACED HIGH IN THE ROOM. This is because of the buoyancy of gas. Carbon monoxide is lighter than air. When released into the atmosphere, it will rise and disperse to other spaces. A detector placed at a high point in a room is better equipped to discover gas early. Gas will always move up and away from the center. Spaces, such as corners will fill faster. Place detectors with this theory in mind. Units should not be lower than nose level.
2.
A carbon monoxide detector recognizes carbon monoxide, a colorless, odorless, tasteless and highly toxic gas. The correct height for a carbon monoxide detector is KNEE HEIGHT ON THE WALL This offers protection while sleeping, which is when you are most vulnerable to carbon monoxide poisoning.
3. Many of the detectors are able to be plugged into an electrical outlet. The reason being that, since carbon monoxide is a heavy gas, the detector should be placed BELOW BED HEIGHT where it will detect the gas before anyone is harmed by it.
