- Massachusetts
but yes one of the reasons they run cooler, is unlike gas aspirated combustion engines, they have a wide open intake, no throttle valve that closes off in coming air, the engine speed and power is controlled at the injectors by limiting the amount of fuel the engine receives, (you don't want to hit one with either while running) this constant flow of air allows the engine to run much cooler, and when you add super chargers and or turbo's it can run even cooler.
I am sorry but I am calling you on that it takes a certain air / fuel ratio to burn the the fuel efficiently and a air valve on the intake does not change that ratio. Turbos or supper chargers do almost nothing at idle and when they do start pushing air in the temps go up. (More air pressure / more fuel burned etc.)
