You are almost correct. The taps on the high voltage side did not provide the proper turns ratio to convert 240v to something under 480v. The lowest was 511.
What I did was pull out one winding and tap into it with a split bolt.
I now get 476 volts, it seems to work nicely. I may be losing a little bit of kVA, but I do not care.
i
You are in violation of the MFG's published data for this xfmr, and the NEC. Sure it will work until the insulation system breaks down. Below would be the proper application and solve prior post issues.
  Print This Page
Email This Page
Search Parameters:
e-Catalog*> Transformers > Dry Type Vented >General Purpose;Phase:3;PriVoltage:240;SecVoltage:480Y/277;KVA:45;Coil Material:AL;TempRise:150
Transformers,Dry Type Vented
Product #: 9T83B3053
Short Description: AL 3P 45KVA 240-480Y/277
SPECIFICATIONS
Category	 General Purpose
Phase	 3
PriVoltage	 240
SecVoltage	 480Y/277
KVA	 45 KVA
Coil Material	 AL
TempRise	 150 ?C
ElecShield	 N
SubType	 VENTED
Frequency	 60 Hz
UL	 Yes
Impedance	 5.8 %
FrameSize	 EE73
cUL	 No
CE	 No
Width	 23.8 in
Depth	 18.4 in
Height	 32.2 in
TempClass	 220 ?C
AmbTemp	 40 ?C
InsulSys	 IS-19C
Taps	 (+2,-4 2.4%)
GSA Compliance	 No
GO Schedule	 67A
List Price	 $8179
View Larger
Publications/Resources
9T83B3053
Additional Resources for General Purpose
Application and Technical
Brochures
Catalogs and Buyers Guides
Data Sheets
Drawings-Outline and Dimensional
Installation and Instruction
Material Safety Data Sheets
2004 CSI Master Format
1995 CSI Master Format
GE Type QL transformers meet NEMA TP-1 efficiency standards. They are available with aluminum or copper windings and utilize a UL recognized 220?C insulation system.
-Quiet Performance
-Core and coil assemblies are mounted on rubber isolation pads to reduce noise
-Bolted coil terminations
-Single-piece front/back is easily removable for service
-NEMA 2 drip-proof enclosure is standard; weathershield kits are available for conversion to NEMA 3R outdoor configuration
-Qualified to the seismic requirements of IEEE-693-1997 and IBC-2003
-Copper or aluminum windings
-Copper ground strap
-Robust packaging with top and side protection protects against shipping damage
-Accessible mounting flanges with front/back slotted mounting holes make installation easier
-100% factory tested for shorts and coil integrity, current and loss, voltage, impedance and noise.
-Clear, comprehensive documentation and labeling
