Don't you have a consulting rate?
If you don't have one then set one up and tell them your client of this X amount to come and tell them how to do it. If you don't have a rate then raise your present rate for that job to include the modiest charge of covering/consulting for them and your time.
If they are fishing for how to, and tap your knowledge and experience on the matter aren't you, if present for various meeting per the same "job" are you not worthy of compensation?
It seems even worse to use your time and knowledge to be used to set up for them to in-house it!
Around here it's not uncommon to have people placed on the job, both white and blue collar -for both long and short durations, it's done everyday and the meter is running, and people are covering thier expenses and making profit.
Besides it's the first of the year, second quarter for most companies, raise your rate for this company... JMO
i have a customer PITA factor i use when bidding work, that allows for this sort of stuff.
i've been compensated fairly for the time i've put in with them for the last couple years.... and they have gotten fair
value for what i've done.... what annoyed me is the rudeness of it, not the financial aspect.
i have a simple, for me, method on my income.... i figure out what i want to have as a net income for a month.
i take a dry erase pen, and i write that number on the inside of my windshield, just above the horizon, so i'm looking
thru it as i drive down the road.... so i'm not consciously staring at it, but it's always in front of me... once it gets
into the subconscous, coincidences and situations show up that bring me opportunities that end up with that amount
of money showing up.
there is only a couple reasons why a person wouldn't do something like that.. first, that cynicism and disbelief would
keep someone from even trying, and the second reason, is that it leaves you naked so to speak, in front of the whole
world... cause you will get asked whats with the number on the windshield......
however, before i can write down a believable number, one that i can believe, i need to have a good record of what my
expenses are, so i know what to ask for.....
when i first started trying this, in 1991, work in this area was horrible.. there wasn't any.... and i figured i HAD to have
$5,500 come in the door that month, or i was screwed... so i wrote $5,500 up on the windshield, and went about doing
the stuff that showed up in front of me.....
and two days later, my wife's car wouldn't start... went thru the phone book, and found a good RX-7 mechanic nearby...
dropped the car off, and he gave me a ride back home, and asked what i did... i said i was an electrician... and he said...
can you put in can lighting?...
he had an 1,800 sq ft house.... we put in $6,300 worth of can lights in the next two weeks.... i've had the weirdest stuff
just show up.... i started increasing the number on the windshield, and over a period of about 7 or 8 months, it went from
$5,500 to $12,500 a month, and i discovered i could work myself to death with this.... six 12's a week.
so how much is on the windshield for january?  $10,300. it'll show up.
but thanks for the insight about a consulting rate... i need to have something like that for situations like this.
