Doesn't seem funny to me.I know it seems funny to look at if you are not use to seeing it as single phase.
Given that there are three different phase angles involved I just don't see how it could reasonably described as single phase.
its considered an open wye
Gaslighting is a form of psychological abuse in which false information is presented with the intent of making a victim doubt his or her ownmemory and perception. It may simply be the denial by an abuser that previous abusive incidents ever occurred, or it could be the staging of bizarre events by the abuser with the intention of disorienting the victim.
	Call it what it is -
According to ANSI C84.1 it is a 120/208Y volt service (1ph, 3W, open-wye) derived from a three phase, 4-wire system.:lol:
It does makes sense guys. Of course.
But I do find it strange that I have never had the opportunity to provide a load center of panelboard that would be ordered as such knowing that one labeled for 120/240 could be applied as such.
For some reason I have never had any oportutities for inquiries regarding 120/208 1ph3w.
Thanks for pointed that out.
In residential there is little 240V equipment that would not run at 208V. In fact most residential heating equipment, like ranges and water heaters, often have adjustments to their thermostats to accomodate the lower heat output. Devices with motors, like air conditioning and pumps, are available with 208-230/240V ratings.I probable have Jim but the darned thing may have been few and far between. I've read a lot of one lives and can't ever remember discovering one there. But, I certainly agree that it is a logical means of distribution. To be able to use the 1ph 208 would be of concern since it is more common to see 1ph 240 devices. 208 may be used for lighting I would suppose.
