resistance
- WA
Can anyone tell me if Genrac make the engines for Honda generators? I recall a thread that said something of the sort.
Small portable-5500wAs far as I know Generac had all their engines made by someone else. Now I'm not saying Generac and Honda don't buy from the same supplier.
What size unit are you talking about?
Thanks for your detailed input!!!On the portables over the years I have see a wide verity of engines used from B&S, Onans, Kohler, Wisconsin's, Tecumseh, and lately some Honda's, but on the air cooled 1 liter used on the Guardian series they use the same engine from the 14kw to the 20 kw the 8kw is a similar version of this engine with a single cylinder rated .4 liter, and the 10 kw is a .5 liter twin cylinder version, these air cooled engines are specifically manufactured for Generac as the have the name embossed into the castings, and the Guardian series engines all run at 3600 rpm, after you get above the 20 kw things change as now they begin to use water cooled engines only, mostly 1.5 GM 4 cylinder industrial blocks on the 25 and 30 KW jumping to 2.4 on the 45 and 60 kw still a 4 cylinder
When we get into the Quiet source series the 22 and 27 kw use the same 2.4liter 4 cylinder used above but now at 1800rpm and on the 36 kw the GM 4.3 industrial V-6 (older 35kw units use the 4.2 that just had a shorter stroke) looks just like the motor that was in my Grand Am except it is all cast iron not aluminum with no fuel injection, now when we jump to the 48 kw we also jump to a 5.4 V-8 version of the GM 3rd series small blocks in the 4800/5300 platform, just longer stroke industrial all cast iron block and head, even says Vortec on the intake which is a GM trade mark for their truck motors.
The above is much inline with what Kohler generators use, the .4-1.0 liter air cooled engines do look different from any other small engine manufactures engines and Generac will tell you they manufacture them, but I'm not so sure on that.
I believe what you said is what I heard. At one point in my career, I was called to install an ATS, but wasn’t sure which generator was the best. So I asked here--after many put Genrac down. Then someone here said Genrac--and for the most part others--had the generators manufactured by the same company.My guess is that Honda makes the engines for other manufacturers. But what do I know.
Can only go back so far when I search. Oh well!! :slaphead:
What is it you need to know about them? Are you looking for parts? One of us might know what fits. There is a lot of interchange, but we need specifics.
