Yet you complained about this :It is not your diagram that is wrong.
So post a correctly labeled one.You have an unlabeled diagram
The only common connection between the two loads is a hot, why wouldn't you use it as a reference?Sure, you can have things connected end to end as well as either end to neutral.
The end to end load would be connected between two hots. Why would it be reasonable to designate one particular hot as a common reference? Common to what?
But again you are thinking of the neutral as the only point of reference. Have you ever worked with the 60/120V circuits used in recording studios? How about multi-tapped control power transformers with both 24V and 120V outputs?My reference was to 120-0-120. But the comments would be equally applicable to 180-0-60.
First part:
I don't suppose that you would argue with the point that a transformer wound to give 120-0-120 even if it is two isolated windings connected in series will give 240V end to end.
Second part:
Suppose you load the two 120V supplies, one with a 40 ohm resistor, the other with 60 ohms.
This cancelling of the currents in the neutral is one of the merits of a 120-0-120 system
Why does it happen?
Why do you keep ignoring what is being said,
is what you posted.You have an unlabeled diagram
Can you not get it through your thick head that I don't have problem with your diagram. There is nothing wrong with an unlabeled diagram. It is your absolute statements made against an unlabeled diagram that is wrong. Even making absolute statements against a fully labeled diagram is questionable, but is at least somewhat defendable.is what you posted.
So post what you think is a correctly labeled diagram.
No. Just as the most logical since it is the only single common point.But again you are thinking of the neutral as the only point of reference.
Recording studios, no.Have you ever worked with the 60/120V circuits used in recording studios? How about multi-tapped control power transformers with both 24V and 120V outputs?
For the resistive loads I gave, the voltages and currents are in phase for each half of the circuit. Restive loads do that.It happens because the two load currents oppose each other, not because the voltages do.
Fine.Can you not get it through your thick head that I don't have problem with your diagram. There is nothing wrong with an unlabeled diagram. It is your absolute statements made against an unlabeled diagram that is wrong.
Did they have common points that were not neutrals?But multi-tapped transformers, yes.
But, based on the notations I placed on your diagram, the voltages do not have a 180? shift, they are additive (Vbn ->Vna), and yet the currents still cancel.For the resistive loads I gave, the voltages and currents are in phase for each half of the circuit. Restive loads do that.
The current in the neutral cancels because of the 180deg displacement.
Oxymoron comes to mind.Did they have common points that were not neutrals?
I employed none.No double negatives were required.
That there are a huge number of circuits in operation that work as a result of that 180deg displacement.So, other than the placement of your scope leads, where is the proof that a real shift occurs?
I did quote you, and I did state what was wrong when this topic came up earlier today. Either it is not sinking in or you are being deliberately obtuse and/or deceptive.Fine.
Cite any absolute statement I made that is absolutely wrong.
Be succinct and direct.
Does the range example I have often cited, have a common conductor between the two loads? Is it the neutral of the voltages?Oxymoron comes to mind.
Other than to say Vbn = -Vnb?I employed none.
Hundreds, going on thousands, of posts and I have yet to see a single one saying these circuits, like the rectifiers you are rightly proud of, cannot work. I said there appears to be a displacement based on the way you choose to reference your wiring (not the actual wiring itself). Choose a different reference and there appears to be no displacement. Are you saying my notations, showing 0? displacment, on your diagram, are incorrect?That there are a huge number of circuits in operation that work as a result of that 180deg displacement.
I am not contesting your assumption. I am contesting your absolute statement. Don't state absolutes if they have conditions. It wasn't simply a matter that you "lightly misspoke". You emphatically stated it as an unequivocal absolute.
120205-1133 EST
Does a transistor or triode vacuum tube produce a 180 deg phase shift of a sine wave input? With what connection of input and output does this shift occur or not occur?
It is well known that I do not have the patience for stupid people, and I make no apologies for that. I don't know if you are one, but right now you are presenting yourself as one. If you are not competent enough to comprehend the discussion you are engaging in, then it is probably best to ignore you again.
Right on. Can the orhers see it? From the earliest days of a triode oscillator there had to be the realization of the phase shift between the grid and plate of the triode.
Insults and disparaging remarks are a sign of a desperate man......:roll:
Bes' challenge is to post math and diagrams, well.......
Not only that, but he "Jumpered" to conclusions without actually reading what I wrote. There were no disparaging remarks in what I wrote. He assumed that there were because he didn't read it carefully. I write for a living. I choose my words carefully.Insults and disparaging remarks are a sign of a desperate man......:roll:
Calling the man desperate for charging the phase shift arguement with deception, obfuscation is an ad hominem attack.
As ever, you exude charm.Can you not get it through your thick head that I don't have problem with your diagram.
