hokasonsh1
- whitehall, pa usa
what best describes utilization equipment per 2008 NEC? appliance recptacle, thermal overload, garbage disposal, light switch
			Sounds like a question on a test.what best describes utilization equipment per 2008 NEC? appliance recptacle, thermal overload, garbage disposal, light switch
Better and I could make the case for it if I had to since it "uses" the elctricity to make heat, but its real purpose is still control. There's an even better answer that I suspect the question was looking for.Now I am thinking thermal overload? Yes :?
Indeed :thumbsup:...hopefully I pass this time.
Indeeed garbage disposal is the "correct" answer - but not because it is equipment; so were all the other items listed. See the definition of equipment in Art 100.garbage disposal if it's a test question. even if it's not, it will "utilize" electricity, it is "eguipment", a fridge, freezer, toaster copier machine ad nauseum, as been said before, see definitions, article 100
