Got it ritelec, I'll measure the enclosure and see how thick it is and go from there. On another note, cow brings up the topic of removing the surface covering of an enclosure that would end up underneath a field installed lug. I don't disagree, however, when you bond an elevated neutral bar in a main panel with a screw, what is happening there? The same thing that's happening, in my eyes, when a lug/bar is installed on a non sanded/grinded surface. All you have contacting that elevated neutral bar is the head of the screw which in turn is just contacting the threaded hole of the panel. Same thing no?
