Stopped over to take a quick look at the existing electric in the garage. Ha ha ha ha ha. There is none, or should I say there won't be any until a new permit is pulled and all new is installed. Turns out the existing electric was a plug end attached to 2 individual conductors (could be plugged into back door light fixture with an adapter when wanted) running through a hole in the garage siding to a wad of tape splice to three sockets (2 for lamps and 1 with a plug adapter).
Atleast it's an easy fix- SNIP, SNIP
On the other hand(s)
AHJ said 1958 electrical codes would apply. 1958 zoning would apply.
I suppose different jurisdictions would be different, but I picked up an electrical permit yesterday and it says right on it good for 2 years from date of issuance.
alot of you replied that permit is good for 6 months or a year. Maybe that wasn't the case in 1958. The AHJ in each area is the only one that will decide how to handle a situation like this....In this case it turned out to not matter, but if you were to ever run into this situation, I would suggest not to assume that todays standards, timelines, or anything apply. Do what I did and take 20 minutes and ask your local AHJ.
Thanks as always.
