The Ques. is How many Amps. of continuous load maybe supplied by a 20 Amp. ovecurrent device?
16 Amp's. Reference 210.20. Got the answer. Don't see 80 percent in the word's.
Have you ever wondered why a common household vacuum has a maximum ampere rating of 12a? And check the amp ratings of other common household devices. 15a x.80 (80%) +12a.
Ques. How many Amps. of non-Cont. load may be added to a 30 Amp. branch circuit, which already supplies 11
Amps. of Cont. load? Key Answ. 16,
30x.80=24, 24-11=13 or is it
30-11=19, then 19x.80=15.2. Why is this so wierd. We are thinking that the 11 are allready have 1.25 in there.
It to simple to get wrong.
shall have an allowable
ampacity not less than the noncontinuous load plus
125 percent of the continuous load.
Remember, it all starts with sizing the wire to carry the load and sizing the breaker to protect the wire base upon the wire size.
Is there somthing in the 2005 code that stated 80 Percent? Or how do I get the wording to tell me what it is?
I don't know why 80 Percent stay's in my head. 100 percent/ 125 percent=80 or 80 percent. Is that right?
My mind is playing trick's on me.
I have seen hand held hair dryers that drew 18 amps and had a 15 amp plug. (Troubleshooting a 15 amp breaker that kept tripping....)
I just checked the one here and it is labeled as 1875 watts (15.625 amps). Actual testing showed 1480 watts drawing 13.2 amps.
Vacuums are getting much more efficient. My Hoover TurboPower 6000 uses less than 8 amps.
It probably drew 18 amps because nobody cleans them.and a 15 amp breaker will never trip drawing 15.625 amps....
Why would that make it draw more?
