ramsy
NoFixNoPay Electric
- LA basin, CA
- Service Electrician 2020 NEC
Roger that. I'm having visions of fireworks, this joker calling the inspector & license board, and giving my business card to his attorney.Owner would be the first to point at you if those stabs burnt again.
Supplier identified unmarked 1? meter center as SEIMENS / MURRAY from photos, and attributed arc damage to improperly seated Challenger brand breakers. Owner won't pony up for replacement - asking me to quote repair with file & sandpaper.
View attachment 6621View attachment 6622View attachment 6623View attachment 6624
110.12(B) Integrity of Electrical Equipment and Connections.
Internal parts of electrical equipment, including busbars, wiring terminals, insulators, and other surfaces, shall not be damaged or contaminated by foreign materials such as paint, plaster, cleaners, abrasives, or corrosive residues. There shall be no damaged parts that may adversely affect safe operation or mechanical strength of the equipment such as parts that are broken; bent; cut; or deteriorated by corrosion, chemical action, or overheating.
Relocate the breakers to a different stab. If not enough room, replace guts. If not possible, change panel. In that order.
I don't let customers tell me how to make my repairs, suggestions are appreciated, but we're the professionals here.
Why in that order? You offer the lowest price and short term repair first? Relocating to another part of the bus should be the last choice... both for my wallet and the customers long term benefit.
You wouldn't think that the drywall overspray wouuld have had anything to do with I. If the breakers weren't in place at the time it was sprayed the bus could have been sprayed too. From what it looks like to me is the breakers weren't in pace as you could have seen the outline of the breakers if they were.
The original contractor should get gigged on this buy it's probably way to late to do that.
The electrician is an idiot for placing breakers in that panel without cleaning or replacement. Very irresponsible. lack of good workmanlike installation.:rant:
Price the repair higher than the replacement.
Repair = $1000
Replacement $800
