zog
- Charlotte, NC
Owner won't pony up for replacement - asking me to quote repair with file & sandpaper.
Explain to the customer the purpose of the silver plating and what will eventually happen if you just file/sand them.
Local IAEI Chapter provided more information.
Regarding attempts to field repair electrical equipment, or change guts:
1) Regardless of permits or lack of AHJ enforcement, under authority of Federal OSHA 1910.303(A), 1910.399, NFPA 790, & 791, claims adjusters from Bad-Faith insurers can void property-owner policy and deny claims with any evidence of altered electrical equipment, which is missing labeling from an approved Field Evaluation Body (FOB). An expense typically in excess of U$D 3000 and several months to complete; FOB approved fabrications, modifications, & combinations are avoided where off-the-shelf solutions exist.
2) Unidentifiable equipment missing OEM labels or name plates may be suspect of modification or fabrication.
The electrician is an idiot for placing breakers in that panel without cleaning or replacement. Very irresponsible. lack of good workmanlike installation.:rant:
