Rick Christopherson
I don't disagree. The difference is that you know that this is just a model of the system. These guys can't seem to make that distinction. Because the math model fits the system well, they mistakenly extend that to mean that the math model defines the system, instead of the other way around.So an equivalent circuit for a voltage source that consists of an ideal voltage source and a single equivalent series impedance is more than adequate for many problems. From this I am satisfied that I can get sufficiently good results in analyzing a real normal center tapped secondary power supply by use of two ideal voltage sources and their equivalent series impedances.
Mivey's mishandling of your sawtooth example makes this quite clear. He has gotten so accustomed and complacent with the application of his trig identity Sin(wt) = -sin(wt+1/2T) that he forgot that it doesn't apply to all periodic functions. He was relying on this identity to be able to claim that an inversion is the same as a phase shift, so instead of drawing a phase shift, he drew an inversion.
