Disclaimer:  I am not a "fuse guy".  So please bear with me and correct/educate me if I use a term in the wrong context.
			... If no,I think the rupturing capacity of the fuse might have been exceeded so that even though the fuse failed catastrophically,it nevertheless caused no damage to the downstream equipments it protected.Correct?
TM -
Look at a fuse curve - pick one that shows a band instead of a line:  On the left side the line shows where the fuse starts to melt.  The line on the right side of the curve, the fuse is guarranteed to be melted clear.
If the selected curve is a line instead of a band, then there will be words telling about the melting to opening time tollerances.
In both cases there will be test specs with the X/R ratio, voltage, temperature.
Now let's look at all of the posts with anecdotal catastrophic failures:
I read all of the posts about the blown up, burned up fuses, and all appear to be mis-applied (application out of fuse spec to interupt), or poor contact fuse holders, or in the case of expulsion type - worn out.
So, if you are telling me that a miss-applied, poorly installed fuse, used near the rating limits, it may explode.  If that is so, I am going to say, "So what?  Why would you expect anything different?  If one is planning to mis-apply any piece of equipment  Why would anyone ever think they would know what exactly what it would do.
So, here is the question: The term "rupturing capacity" has been used in several posts and I am not familiar with it.  I have looked a lot of fuse data sheets and I do not recall ever seeing a column marked "rupturing capacity".  Can you give me a definition?
If this is meant to be some sort of an i^t value,  am thinking that a fuse will stand any i^2t value along fuse curve line where it is rated to open.
ice
