K8MHZ
- Electrician
I was going to suggest the voltage drop method until I thought it all the way through.
Such as:
Find the biggest load your circuit breaker can handle and connect the spool in question in series with the load. Now, powering it up should show enough voltage drop do to the math. I forgot to take into consideration that the spool will act like a coil and the impedance won't be purely resistive, and the fact that the spool would turn into a large electromagnet, pulling tools and sharp metal objects toward it at a fairly respectable velocity.
Such as:
