Fuse failures
Two simple tests to ascertain the health of a fuse in a given batch.First test.The fuse should not blow for current up to 140% of its rated current within one hour.Second test.The fuse should blow for current beyond 160% of its rated current within one hour.Of course the second test can not be performed on all fuses in the batch but only on a select few.
Again, what type of fuse are you going on about?
The point at which fuses open depends on the fuse.
Again,all fuses.
Do you have any difference of opinion on this?
Again,all fuses.
Yes, I do.
Your tests described here are meaningless and pointless without knowing about the fuses characteristics.
Look at this graph of a common fuse here
http://www.cooperindustries.com/con...Resources/Data Sheets/Bus_Ele_DS_2011_BAF.pdf
Now compare it to the slow blow version here
http://www.cooperindustries.com/con...Resources/Data Sheets/Bus_Ele_DS_2028_FNM.pdf
What do you notice?
1) The fuses are very different
2) Per design both would fail your test 1.
3) Per design both would pass your test 2
This makes your test pointless.
Unfortunately,both the links do not open.
The controversy is about test-1.
Is it possible to reproduce the curves here?
or
What is the time period for 140% current through the fuse as noted from the fuse curve?
Disclaimer: I am not a "fuse guy". So please bear with me and correct/educate me if I use a term in the wrong context.
... If no,I think the rupturing capacity of the fuse might have been exceeded so that even though the fuse failed catastrophically,it nevertheless caused no damage to the downstream equipments it protected.Correct?
TM -
Look at a fuse curve - pick one that shows a band instead of a line: On the left side the line shows where the fuse starts to melt. The line on the right side of the curve, the fuse is guarranteed to be melted clear.
If the selected curve is a line instead of a band, then there will be words telling about the melting to opening time tollerances.
In both cases there will be test specs with the X/R ratio, voltage, temperature.
Now let's look at all of the posts with anecdotal catastrophic failures:
I read all of the posts about the blown up, burned up fuses, and all appear to be mis-applied (application out of fuse spec to interupt), or poor contact fuse holders, or in the case of expulsion type - worn out.
So, if you are telling me that a miss-applied, poorly installed fuse, used near the rating limits, it may explode. If that is so, I am going to say, "So what? Why would you expect anything different? If one is planning to mis-apply any piece of equipment Why would anyone ever think they would know what exactly what it would do.
So, here is the question: The term "rupturing capacity" has been used in several posts and I am not familiar with it. I have looked a lot of fuse data sheets and I do not recall ever seeing a column marked "rupturing capacity". Can you give me a definition?
If this is meant to be some sort of an i^t value, am thinking that a fuse will stand any i^2t value along fuse curve line where it is rated to open.
ice
... Because the problem is on heating, the paper emits conductive vapor which on being absorbed by sand makes it in turn conductive.The result is when the fuse tries to interrupt a fault current,the fault current may continue flowing through the sand even after the fuse element is broken!
This is another one I have neve heard of. This is a problem when one has lived such as a sheltered as I.
Do you have any publish data or even your own test data that shows the sand turns conductive?
ice
Yes, I do.
What do you notice?
If a straight vertical line is erected at 140% of rated current of a fuse say 1A in the above common fuse curve,it is almost parallel to the fuse curve.Same is true for any other fuse curve including the slow fuse type.So what is your problem here?
So you choose to ignore the difference in time.
So in your view the normal fuse and the slow blow fuse are the same. Interesting.
Guess why it stopped at 100 seconds,but I really detest spoon feeding.
I feel much the same way about rudeness and willful ignorance.
Here are a couple of pictures of the fuses which you had trouble with the link.
How would the 3A fuse fare at 100 seconds with your tests in post #84?
I requested you to find for yourself why the fuse curves stop at 100 seconds.
You did not.
The reason is the curve become almost parallel to the vertical line erected at 140% of rated current of each fuse.
