Paper Dolls
Paper Dolls
We called that playing with "paper dolls". Get an architechial plan, cut out a scale figure of your switchgear and "drive" it throught the building.
Despite all the bittiching about different switchgear manufactures they can be a help. They all provide rigging, handling and storage instructions. IF something goes south and you weren't following their instruction it could cost you $$$.
Unloading, moving, and storing electrical equipment requires prior planning. Remember the 6Ps!
Paper Dolls
A few things could come into play very quickly. If this is a real cause for concern go to the Architectural plans and check the door size(s). In most cases this is where they have 8'-0" doors and or roll-up doors usually equal to double wide door way each 36" wide.
I'll go on the record and say "NO' this should not be a concern, first off the building is usually dryed in. These means that weather should not be a concern to anything that would occupy the space, only then does the equipment get set.
IMO, you don't want gear on site, unprotected from the weather and one certainly don't want other trades working around it (unpackaged) or over it. No other trades care about the gear and will use it and abuse it at will.
