I have a stairwell that needs a three way switch at top of stairs. I discovered the bottom switch is being fed from knob & tube wiring. To strap wire on the surface, I was going to use armoured cable, but now amthinking i need to tape it where it enters the wall close to other wires. No cantact will be made, but an extra precaution. The trick I think is the existing knob and tube has no ground/bond... do i use the armoured cable and strap it to the box? ...maybe use building wire?...shielded where it may get mechanical damage? Thanks in advance for your feedback.
