frankft2000
- Maine
I saw one installed in a panel to feed another panel, but I don't know what it is called.
They had a lug of some sort that went into the breaker hole and you tightened it down, then it had a spot for 2 wires to hook into it. They had this set up for each phase, so they had a feed coming in from the utility, then jumping back out to the 2nd panel. Note, there was a disconnect under the meter that kept everything fused right.
Anybody seen such a thing?
