Ken9876
- Jersey Shore
Here is my situation, went to a home today for some home inspector issues all went well till I got to a detached finished shed building. HI reported no equipment ground, upon checking I find the PVC siding box fed with AC cable no connector, no anti short bushing entering a plastic box. With a little further investigation I find more issues at the shed panel, N-G bonded, no GES, a mix of AC and MC cables terminated incorrectly, MC grounding conductor cut off flush with the cable end. The inside of the shed is finished, but I know just from what I have seen on the surface the rest is probably a mess as well. So my first thought is to tell this guy I need to go through the entire building and correct as needed. I doubt a permit or inspection was ever obtained. Just wanted to get opinions on other options.
