OK, This sounds fishy to me but has anyone heard of an OSHA reg that states: If the setup (tripod,etc) takes longer than the actual task, then you don't need to do it. (Probably not in those exact words - but I can't find anything remotely like that.
Thanks!
Spot-on. I think the OP's employer/supervisor is trying to reduce cost through deception. :thumbsdown:And you won't. OSHA doesn't care how long it takes to comply, or how much it costs.
And, look at it this way: the tripod isn't there just to save your life, it's to save the life of your partner, who'll probably climb into the manhole to save you, and die trying. The tripod is there so he can pull you out without going in himself.
