Looking for some other opinions here. Example: I have an older house with a pipe electrode driven under the fuse panel in the center of the house, with the EGC connected from the panel straight to the pipe. Because the new smart meters aren't particularly fond of lightning induced surges, I want to drive an additional rod at the meter socket and connect the EGC from the new rod directly up to the meter base.  The two will not be connected together except through the grounded conductor (neutral).
Another example: I am not sure an older house has a grounding electrode installed at all. I drive a rod at the meter base and install a GEC from the rod and the meter base. What I don't realize is that the water pipe is used as the electrode and is connected at the fuse panel in the house. Again, the two only share a common neutral connection.
What, if any, problems do you see with this installations.
