Hello,
I'm installing 50lb chandelier in a 18ft entry. The junction box in attic will need to be replaced to support the heavier light fixture.
My idea is to remove the old junction box in the attic and connect a hand winch to a joist in the attic. Then, lower the winch cable thru the hole in the ceiling and down to the floor in foyer. Then connect a junction box to the winch cable, connect chandelier to junction box, and then (using winch) lift the chandelier up into the hole in the ceiling.
My question is how can I safety connect the new junction box to the winch cable? And, once I've lifted the chandelier into place, how do I secure the new junction box to the attic joists? Or, does the winch become a permanent fixture in the attic to raise/lower the chandelier when it comes time to replace bulbs etc.?
Has anyone attempted this before? Basically, I'm trying to build my own chandelier lift using a hand winch.
Thanks!
Thanks!
