Acid atmosphere?
There is corrosion on the grounding bushing which would not have come with the meter socket. So I would say the cause has to do with the environment it is in, possibly a leak as was mentioned.maybe a manufacturing oops with dissimilar metals or wrong anti corrosion spray at install,,,,,your guess is as good as mine.
dick
Why haven't the copper conductors themselves corroded,
like the copper [ and other ] components on the panel ? :blink:
:thumbsup::thumbsup:Noting that this meter socket is mounted on stucco, one thing come to mind, was the stucco pressure washed in the last year with a acid or alkaline based cleaner?.
Pressure washers are like mice, they will get into the tightest spots and can render even what should be water proof full of water, a rain tight meter cabinet doesn't stand a chance.
I DID see the corroded sockets......Just wondering why the conductors"Look at the meter sockets they are corroded."
are not equally corroded, if a powered spray washer is the culprit,
...which I believe, may be the cause.
Is water able to follow those conductors from the meter right into the lug inside the panel in that photo? There may be no environmental issue indoors other than it is arranged for water containing acids or something to flow right into the panel from outside.Guys I didn't think anybody was even
going to reply to this.
I Didn't see any new email notifications
I went there for different complaint
I only discovered the socket
when I yanked the meter
That morning.
30 feet away indoors as a remote distribution that has the same exact problem and that was apparently because of the whole house flicker.
I swapped that out and now we're waiting for his approval to change the Periscope and the socket
The closest answer seems to be
environmental conditions
its kind of damp there
there's not a lot of temperature variations
The house was not pressure washed lately
That this new owner knows of
It must be environmental in the air
because the remote panel indoors
In the garage had the same look to it. View attachment 7678
Let me see what I can post some better pictures when I get to computer
I actually had another question about adding a panic button old house lights flashing alarm bellringing system to existing finished fancy house I was going to posted another question
And I just came from another house that was from one of Ronald Reagan's coworkers and they have the whole thing wired up with the Leviton 6312 and the panic button and that's sort of what I want a little inside
That morning.
