The industrial facility I work at had a mine at one time so was tied to MSHA and didn't follow a whole lot of the NEC. Now the mine is no longer and it now falls under OSHA which is under the NEC. My question being a licensed electrician is when I go work on a piece on equipment to repair or install, how far do I go with upgrading? For instance a 120 volt 1 hp heater motor that has a plug and cord and that is it. So if I upgrade and add a controller and overload protection then find it is on a circuit with 2 or more heaters then am I obligated to also seperate this from these other motors. It gets pretty complicated from what I see! Thanks for any input.
