Conduit and conduit fittings use two forms of pipe threads. Conduit and female threaded conduit fittings use tapered pipe threads, the same as water pipe. With pipe tape and wrench tight connections they can form watertight joints.
Would this be a bad place to ask if they make a PVC "close nipple"? If so, I apologize. I figured it could fit into the PVC adapters thread instead of making a new thread
I need to connect an ATS to a meter can but I have to fit the ATS into a tight space and it has to be about 3/4"-1" away from the meter can no further. I would like to nipple over in PVC to avoid bonding the nipple.
| Select part number for detailed information and technical drawing. A connector used to transition from plain end PVC conduit to a threaded metal or PVC female bell. Can also be used to connect PVC conduit to a box or other threaded body with the use of a lock nut. The fitting consists of one solvent weld female end and one threaded male end. Both ends will fit the same diameter conduit. | |
| 1/2" through 1-1/2' | ||
| 2" through 8" |
