mstrlucky74
- NJ
I know RGS usually come with a threaded coupling but if you were using split coupling what would you do. Use RGS without the coupling? Cut the pipe? Thanks.
I don't understand the question. A split coupling is also threaded. A split coupling takes the place of a standard coupling.I know RGS usually come with a threaded coupling but if you were using split coupling what would you do. Use RGS without the coupling? Cut the pipe? Thanks.
Yes.Actually the coupling can be removed on RGS, correct?
Yes.
Thanks. What is the purpose for using a split coupling instead of a standard coupling with RGS. Is it for tight spaces where channel locks can't be used?
See the link in post #3 and they are used for the reason you mention.When you say "split" coupling are you talking about a three piece coupling or union? The reason to use those is in places where you can not turn either entering pipe to install/tighten the coupling.
As kwired mentioned. GRSC (or RGS) is right-hand threaded, so a typical installation must start at one end, then pieces threaded together in succession to the other end. For some installations, it is impracticable to do this. Say for example, the "end" enclosure or box is already secured and it has a threaded hub entry. The last piece has to be long enough to thread into the hub and at the same time a coupling on the second to last piece. That is impossible with a standard coupling at the end of the second to last piece because of both length and thread direction. The solution is to thread the last piece into the hub then use a split coupling, or three-piece coupling, to complete the run.Thanks. What is the purpose for using a split coupling instead of a standard coupling with RGS. Is it for tight spaces where channel locks can't be used?
Roger
I have to say I didn't know they made such a thing as what is in the link in post 3. With that split side are they limited to dry locations only?
They look like they would be real easy to use, or a big pain in the rear, but nowhere in between.
about the only place on the left coast that uses GRC very much is either a listed occupancy, or a food prep plant with washdown,
and as a result, i've not seen these used much... there are ridgid setscrew threadless couplings, again not suitable...
around here, we use ericcsons. you order a 3 piece coupling, the only thing that is stocked is marked CL1 DIV1.....
Unless nobody ever buys them, I find it hard to believe the "non classified location" versions are not stocked.
Looking in my pricing information, last 3/4 inch 3 piece coupling price was about $5.00, the last price for a hazardous location rated 3/4 union was about $16.00. I normally don't use the latter unless it is in a hazardous location.
i believe you... last time i needed a union, i got some 3/4" ones from the wholesale house marked CL1 DIV1, and when i asked,
they said there was no price difference so they quit carrying the unclassified ones like the ones with the threaded band under the
cap...
Have you done electrical work before?
yeah but maybe he's learning stuff?I don't think he has ever been on an electrical job.
He wasn't telling the truth when he said that when he changed his identity there shouldn't be any more dumb questions.
Even I learned there was a "split coupling" I never knew existed from this thread.
