JJWalecka
- New England
Who else makes a heating box/blanket for PVC?
Besides Greenlee, Current tools, Gardner Bender and Ideal
What's wrong with the ones from those four manufacturers?
My boss?s dad made one we use all the time out of sheet metal, high temp insulation, and an oven heating element.
I believe they were alsoHe was part of that Greatest Generation bunch.
Sounds like a great idea
352.24 Bends ? How Made. Bends shall be so made that the conduit will not be damaged and the internal diameter of the conduit will not be effectively reduced. Field bends shall be made only with bending equipment identified for the purpose. The radius of the curve to the centerline of such bends shall not be less than shown in Table 2, Chapter 9
In my opinion a homemade PVC bender is an NEC violtion.
IMO that is a bit of a stretch. I agree with the bending radius, but as long as the pvc is bent in a manner as not to harm the pvc, what is the difference between a boughten pvc heater and a homemade one? Will a inspector be able to tell by inspecting the pvc after the fact as to how it was bent?
Not UL listed if someone got hurt using it he might have an issue but I still thought it crafty.
I do ask those that disagree with my opinion what exactly those words in the NEC mean?
I think the worst I ever did was pour a can of glue in the trench and set it on fire to heat the pipe.It was and I have respect for ingenuity, I just feel it happens to be an NEC violation.
I have also used things not identified for PVC bending to bend PVC, I am not an angel.
I have a Greenlee that hot box that has always worked great. But if you can swing the $ you can not beet the Hotbend.
The site you gave a link to says free 15 day trial. Next time you have a bigger job that will require a lot of bending try it.
