K8MHZ
- Electrician
Yes, but where does the energy for that come from in the first place? The vehicle propulsion system maybe?
Maybe not. The original posted is claiming 2-3kW. If true, that would be in the region of 200A at 12V. Far more than the sensors would require. So, if you wanted to harvest it for other uses, you would need to extract it from the rotating wheels and into the car somehow and that would require some form of sliding contacts.
You are correct. I was just trying to explore possibilities. The sensors would only need microwatts.
As for the 2-3 kW.....If it were possible, that much power would have to have either violated the laws of physics or put some additional drag on the vehicle. You won't get 4 hp from the wheels without needing 4 hp from the car, as has been pointed out. The advantage of the system, to me, would be a place to put power on rotating parts connected to the wheels.
The sensors are a small load on the wheel. If 1 hp was available at each wheel, this may be applied to braking or traction control systems. Maybe even an air compressor that could compensate for small leaks in the tire.
But anyway, the cart is already before the horse. Without a working model we can volley dreams and arguments all day long and nothing will be proved.
Like it has been said, 'If you build it, they will come.'
