masterinbama
- Huntsville Alabama
Why is it always a neutral? In the picture the only slot left is the neutral one. The melt looks like it's from left to right! IE hot to neutral. Let's take for example that in fact this is a resistive load, most can and will take all the juice that can be supplied to it, even with it being monitored for demand. My question to you is did you test the circuit with a meggar or just cut back and tap off new leads? Did you test the draw of the space heater to make sure that it's within it's tolerances? If the equipment has a road map(schematic) you could see and figure out if there is an imbalance in the circuits of the equipment that needs to run home on the neutral.
Wow- that is the worst burned up recep. that I have seen.
One of the 2 screws on the neutral side was not even tightened.
Seeing what is left, how could you even tell?
I will agree there was probably a "glowing connection" involved here, and would guess it was most likely on the ungrounded conductor portion, since there is more of the grounded conductor portion still intact.
To stir up another debate - would have an AFCI detected this and opened the circuit?
Since we have no idea if an arc was even involved, we can't really have much of a debate about detecting it.
