steve66 Senior Member Location Illinois Occupation Engineer Feb 14, 2013 #1 What size ground wire (equipment grounding conductor) is required for a 150 amp feeder? Do I use the row for 100 amp (#8 EGC) , or the row for 200 amp (#6 EGC)? Is it sepcified anywhere in the NEC text?
david luchini Moderator Staff member Location Connecticut Occupation Engineer Feb 14, 2013 #2 Use the 200A row. The table 250.122 says Rating or setting of OCPD ahead of equipment (Not Exceeding.)
cpinetree Senior Member Location SW Florida Feb 14, 2013 #3 steve66 said: What size ground wire (equipment grounding conductor) is required for a 150 amp feeder? Do I use the row for 100 amp (#8 EGC) , or the row for 200 amp (#6 EGC)? Is it sepcified anywhere in the NEC text? Click to expand... Top right column heading - Not Exceeding (amperes) 150 exceeds 100 so you must use 200
steve66 Senior Member Location Illinois Occupation Engineer Feb 14, 2013 #4 Duh - on my part. I missed that in the table.
