DaveBowden
- St Petersburg FL
I'm trying to bid a new house that is being built with prestressed hollow core planks for the flooring system for the first and second floors of living space. The bottom of the first floor plank will be the ceiling for the garage area.
My problem is in over 40 years of wiring here, I've never worked on one of these types of jobs and I sure would appreciate some advice.
From what I can discern from the prints, the garage ceiling will not be covered and everything will have to be surface piped. The only glaring problem I see with this are the 3 recessed cans they drew on the outside porch ceiling. I figure the other lights, ceiling fans, and receptacles will all be all right in conduit. It might take a little extra time to make sure it looks good when its finished, but we can do that.
As far as the first floor of living space, would standard practice involve piping on the garage ceiling and using an LB for stuff like the kitchen island?
The plans call for 2 floor receptacles. Can they be core drilled from the top and fed thru the hollow channels in the slab?
How hard is it to run wiring thru the channels in the slabs usually?
Finally, are there any special code requirements for the NM romex if it is run in the hollow cores?
Thanks in advance for any and all help
