Eddy Current
Does a sine wave go up and down or is it like a coil going round and round? If you look on the wiki page for sine wave there is a gif that illustrates a sing wave. Is that true for all sine waves including electrical ones?
			A sine wave (sinusoidal waveform) just goes up and down. The "trace" appears the same as looking at a 3D spiral from the side.Does a sine wave go up and down or is it like a coil going round and round? If you look on the wiki page for sine wave there is a gif that illustrates a sing wave. Is that true for all sine waves including electrical ones?
I disagree. In three-dimensions, it is a spiral, not a sinusoidal waveform.Both. A sine wave is three dimensional.
A sine wave could be considered a planar component of a spiral... but the sine wave is not necessary to construct a spiral. A spiral marks the off-axis end of a rotating radial moving along an axis at a constant rate.How do you propose to generate a spiral without a sine wave?
Mathematically a spiral is a sine wave.
A sine wave doesn't actually exist in a spiral... it is only a sideways projection of the spiral onto a single plane. In the animated image you embedded, note the sine wave only exists on the X-t plane. Any "Y-axis" magnitude of the spiral is imaginary with respect to the sine wave itself.
Nothing.What did you do to your avatar? It moves like it is supercharged now..
A sine wave voltage has two components. Voltage and time.Both. A sine wave is three dimensional.
Part of the brainteaser in this, I think, comes from most of us using electrical objects that are three dimensional.A sine wave voltage has two components. Voltage and time.Both. A sine wave is three dimensional.
A pendulum swings with SHM in two dimensions.
Nope a spiral never changes its value, just its position in the three dimensional world. A sine wave never HOLDS the same value, it constantly changes.
I have to agree with Al, the waves of an AC voltage can be a spiral if the material it is passing through is large enough for the wavelength size, we only reference the wave from a small point that we can only see the sign wave as the wave pass by this single reference point, for a true 3-D image we would be looking at a spiral ball, think of an explosion under water, the shock waves would radiate out from the explosion point in all directions, just like radio waves do in the air when a plane transmits, the sign wave we use to represent AC is just the stationary single point of reference of the wave propagating out from its source, just because we tend to only take measurements from a wire, the sign wave we see is only relative to that point where we took our measurement, if we had a conductor that extended out in all directions from the source we would see this spiral ball radiating out from this source point, while the wave hight of a sign wave is relative to the voltage creating it, and the spacing of the waves is relative to the frequency of the voltage, don't confuse the wave hight with the wave length, as wave length is the distance between each wave in a sign wave as it is in a spiral wave hight is relative to the pressure of the wave or voltage, the 4th dimension is the speed at which the wave travels which is what really give us the frequency as if you were to move your measurement point down the wire at half the speed of light then the frequency would be half the 60hz or 30hz, this is why everything is only relative to the point at which we take our measurement, but if we could see the movements of the wave like we can with kinetic energy in water, we would see that same spiral that one would see in water.
Theoretically . . . yes.. . . it does not exist as a distinct physical shape and it has absolutely no relationship to the 'movement' of electrons or other particles.
Electromagnetic waves move that way. But current is a more localized phenomenon, tied to actual movement of charge carrying particles (except for displacement current, as in a capacitor, and we will ignore that....)Actually I don't see AC current as a spiral but equally spaced rings of waves traveling out from the source at the speed of light....
