UF Connector
What if you get an inspector that doesn't use the whitebook?
A inspector could fail an installation citing 110.3(B) if I used a common NM94 button connector for UF because Arlington only listed NM cable under it's uses?
UF can be installed as NM when following 334 part II and III
Then you take your copy of the White Book and politely show him why you feel the install is correct.:D
