I have a few questions about VFD's. First, I would like to know that if using a VFD removes the need for an overload device. I do not think that it would, but a colleague told me that it does. I would think that I would still need an overload even if the motor is running from a VFD. Also, should I use the NEC tables to size the overload or should I use the motor nameplate data? My last question is just to make sure that it is OK to use a single VFD to drive separate motors that will operate at the same time. Are there any precautions that I should take when setting up multiple motors on a single VFD? Thanks in advance.
