The utility I work with requries 4-wire from the meter socket to service disconnect. The inspector requiring this is deceased. No paper work. Would someone be able to lead us to another utility that requries this and would share their requirements? Or is this all listed in NEC and there would be articles in regards to meter socket,4-wire to disconnect on outside of house with breaker panel 25ft. inside house. The ground and neutral bonded at meter socket,disconnect has ground bar and neutral bar isolated, green screw removed. main log panel in house same ground bar and neutral bar lsolated green screw removed.
All meter loops don't have the disconnect on outside and panel on inside of house but this one we really need help because of the green screws in or out. It not like a nornal subpanel.
Thanks if someone could get requirments or code articles for this hook-up.
