manual transfer switch or double throw switch
Rai136926
seattle, wa
Can I use manual transfer switch or double throw switch, to switch the load side instead of line side. That is I have one incoming line but two loads.
You can but you would have to wire a manual transfer switch backwards. Line connects to load terminals and loads connect to normal and emergency.
Not sure if that is even code compliant or if switch is listed to be used that way.....
THANK YOU THAT IS WHAT I WAS THINKING
C:\Users\kqb\AppData\Local\Temp\msohtmlclip1\01\clip_image001.wmz
