mgookin
- Fort Myers, FL
- Retired inspector, plans examiner & building official
Stainless steel hose clamps would hold it nicely to that pipe. No pentrations, easy install, easy servicing if ever necessary.
The only problem is that it makes the job look like it was done by the wrong type of mechanic.
It's probably a large pipe to be self supporting. You can just use all thread and uni-strut and straps and make the mounting look like every thing else in an industrial plant.
I would use enough strut just in case someone need to run another conduit in the future ( allways happens).
...all threads attached to where? There is a 30' span without any overhead attachment points.
...and every place where the SS hose clamp attaches to the mild-steel pipe, the pipe becomes the sacrificial anode and corrode.
see above.Maybe the all-thread goes up - from the ground? :angel:
Stainless Steel and steel or iron pipe are both iron based metals, as such there should not be any galvanic action.
For a 12/2/with ground cable in 3/4" conduit I think back to back one hole pipe clamps is the way to go to the existing pipe already run, if this existing pipe is a electrical conduit then take a look at 300.11(B)(1)
The self-supporting pipe the OP said will be there.What existing pipe? This has crept in through the posts, but has nothing to do with the OP.
I see the addition. However it is unclear if it can support, either mechanically or legaly anything else but itself.
In the Chemical indutry, it is a definite no-no. Electrical material and installation must be supported off of independent, structural support. When supported off of vessels the designated attachments must be part of the original vessel design, for the purpose.
Be careful...you are probably dangerously close to getting one of these:You use allthread and unistrut to make a large pipe clamp. The allthread is bent into a large U-bolt and fitted through the holes in the unistrut. The same way as a clamp is made for a round column.
If this pipe is mild steel and you were to get permission then you could just have the fitters weld some angle iron or strut to the pipe to use for mounting.
How about staying within reason.......:slaphead:
You just plain wrong here. Can you explain the difference between electrical or marine grade aluminum and plain aluminum? One easily corrodes the other not so much?
see above.
The most common solution I see is to use ACSR quad the change over to a "conventional" wiring method at each end..
Works for untold number of utility installs. Why reinvent the wheel![]()
