acbert
- Louisville, KY
I need to know the possible problem of installing the wrong size battery in an LED EXIT sign. The sign in question does not have a battery in it, but has a test button and receptacle for a battery.
I simply took a battery out of a NEW exit light and put it in this one. The battery was a two cell 2.4volt 800 milliamp. I have no way of knowing what battery was originally installed in the unit.
It seems to work fine. The test switch when pressed keeps the led's on (prior to installing the battery the led's went out when the test switch was pushed).
Is this ok? Any potential danger if this is the wrong voltage battery? What if it's suppose to have a 4.8volt 4-cell battery?
Just need to put my mind at ease or remove this battery if it will cause a potential problem.
Thanks
Thanks
