Something as a follow up to the same topic in another thread.
We have 14AWG being a larger conductor that say, 18AWG.
Bigger number, smaller wire. It kinda runs contrary to simple logic..
From Wiki:
Ouch!
We here in UK, and pretty much elsewhere in the world, us SI units Metric in common parlance.
It is so much simpler. A 4mm2 conductor has a cross sectional area of 4mm2. And 6mm2 is a bit bigger. And a bigger number for a bigger conductor. Logical.
I am familiar with the Brown & Sharpe measurement system.
But I think it is an anachronism.
I can't change what you guys do.
I'm just gently hinting that you are out of step with much of the rest of the world in your use of antiquated units.
From Wiki:
By definition, No. 36 AWG is 0.005 inches in diameter, and No. 0000 is 0.46 inches in diameter. The ratio of these diameters is 1:92, and there are 40 gauge sizes from No. 36 to No. 0000, or 39 steps. Because each successive gauge number increases diameter by a constant multiple, diameters vary geometrically. Any two successive gauges (e.g. A & B ) have diameters in the ratio of approximately 1.12293 (= dia. B ? dia. A), while for gauges two steps apart (e.g. A, B & C), the ratio of the C to A is about 1.12293? = 1.26098. The diameter of a No. n AWG wire is determined, for gauges smaller than 00 (36 to 0), according to the following formula:
d_n = 0.005~\mathrm{inch} \times 92 ^ \frac{36-n}{39} = 0.127~\mathrm{mm} \times 92 ^ \frac{36-n}{39}
Ouch!
